#311692
Tak for en super test! Vi kommer jo ikke uden om Burn in problematikken. I nedstående skriver LG Supporteren (Ivanf) at der er indbygget en funktion til reduktion af Burn In, ved I om den er ændret/forbedret i forhold til C9 ?
<https://www.lg.com/us/tvs/lg-oled65cxpua-oled-4k-tv langt nede og som sp 23/41>
Doug R · 2 months ago
HAS there been any improvement with possible burn in compared to last year's model
1
answer
Answer this Question
Ivanf
· 2 months ago
Burn-in and image retention are possible on virtually any display. However, with an LG OLED TV, any risk of burn-in or image retention have been addressed through the use of technology that not only helps protect against damage to the screen but features self-healing properties so that any short-term image retention that may occur is quickly rectified. It is rare for an average TV consumer to create an environment that could result in burn-in. Most cases of burn-in in televisions is a result of static images or on-screen elements displaying on the screen uninterrupted for many hours or days at a time – with brightness typically at peak levels. So, it is possible to create image retention in almost any display if one really tries hard enough. And even if image retention does occur from extreme usage, it can usually be mitigated within a short period of time by turning the display off for a while, and watching a few hours of varying content (such as your standard TV watching and channel-surfing). The LG CX 65 inch Class 4K Smart OLED TV w/ AI ThinQ® (64.5'' Diag), Model # OLED65CXPUA will have special features and settings to preserve image quality and prevent burn in and image retention...^IFV
#311695
Tak for en god anmeldelse som altid.
Af ren nysgerrighed - i målingen af de forskellige billedprofiler er der ret stor forskel i peak luminance.
F.eks. er Cinema SDR 215 cd/m2 mens Filmaker mode SDR er 91 cd/m2.
Er der virkelig så stor forskel i lysstyrke på de profiler som ellers måler ret ens?
#311705
BCDK skrev: 24. mar 2020, 15:17Nogen ide om, hvornår 48" kommer - også hos de andre producenter?
Har du set et 48" live?
Hvis ja, hvordan var oplevelsen?
LG lancerer 48" OLED fra maj i Europa. Det er dog muligt, at den først kommer lidt senere i Danmark. Det afhænger i sidste ende af åbningen af LG Displays nye OLED-fabrik i Guangzhou, Kina. Den er efter mange forsinkelser nu sat til at starte produktion i maj, men coronavirus kan måske udskyde det.
Sony lancerer 48" OLED i september.
Jeg regner med at vi ser nogle flere 48" OLED-modeller annonceret på IFA-messen i starten af september - hvis IFA da overhovedet bliver til noget i år.
#311707
Mr.DJ skrev: 24. mar 2020, 15:23En anden tanke der har poppet op, ifht. BFI.
Kan BFI mon evt. tjene som en slags supplerende anti-burnin feature? Jeg tænker her på, at når der indsættes en "pause" i lys-afgivelse i dioderne, så bliver punkterne i billedet vel pludselig også mindre "statiske"? Kunne da være et sjovt spørgsmål at stille til LG's ingengiører, om det kan forlænge levetid eller ej! ;-)
Kan selvfølgelig også være at det viser sig at "stresse" dioderne mere i stedet for og giver højere slidtage! Er ikke helt klar over hvordan en OLED diode "arbejder best/mest optimalt" ifht. længst levetid(on/off cycles vs always-on)! Måske en ide til en "nørdet" artikel om OLED's virkemåde? ;-P
Jeg hælder nok mere til, at det kan øge slitage. Der må have været en udfordring i 2019 siden man ikke gik videre med det og siden man i 2020 nu ofrer mere lysstyrke. Jeg tror, at disse hensyn bunder i netop levetid på panelet. Men det er spekulation.
#311709
BlueFox skrev: 24. mar 2020, 20:02 Tak for en super test! Vi kommer jo ikke uden om Burn in problematikken. I nedstående skriver LG Supporteren (Ivanf) at der er indbygget en funktion til reduktion af Burn In, ved I om den er ændret/forbedret i forhold til C9 ?
Risikoen findes helt afgjort. Vi får at vide, at dimming-funktionen (for hele billedet) er ændret en smule i år. Det er vist eneste ændring og de større tiltag stammer fra de i foregående år.
Det er vist over de seneste 2 generationer af OLED-panelet, at man har ændret på størrelsen af nogle subpixels (for at forlænge levetid), indført funktion til at identificere logoer og dæmpe dem, samt denne overordnet dimming-funktion af hele billedet (som i starten var alt for aggressiv, men nu er mere subtil - måske stadig problematisk i visse sekvenser, om end vi ikke kunne identificere nogen).
#311710
Hanga skrev: 24. mar 2020, 20:45 Tak for en god anmeldelse som altid.
For at besvare det kræves en smule baggrundsinfo ift. CalMAN-graferne og SDR-video. Kort forklaret, så er SDR-video et system, der arbejder med lysstyrke som relative værdier. Det vil sige, at CalMAN rapporterer farvenøjagtigheden for det målte niveau af lysstyrke (for hvid). Så farvenøjagtigheden er den samme for hhv. de to givne/målte niveauer af lysstyrke i de to profiler (Cinema og Filmmaker Mode).
HDR-systemet er derimod et nyt fundament under video, hvor lysstyrke defineres som absolutte værdier. Altså kan man på indholdssiden angive, at noget skal gengives som 1000 nits og noget andet som 500 nits (med SDR ville man angive den højeste lysstyrke i indhold som 100% og halvdelen deraf som 50%).
Derfor outputter CalMAN som udgangspunkt flere grafer, når man måler på HDR. Hvis man kigger på f.eks. Filmmaker Mode HDR, så kan man se, at farvenøjagtigheden (RGB balance) angives både uden og med lysstyrke (luminance) inddraget. Og ovre til højre forneden på den mindre graf har man så de absolutte værdier for lysstyrke.
(vil man ændre de absolutte lysstyrkeniveauer i HDR, så skal tone-mapping tages i brug)
bjarnetest skrev: 24. mar 2020, 23:04 Tak for en fin test. I mangler lige prisen. Den er som følger
LG OLED77CX Pris 6999 Euro = 52.260,83 kr (kommer Maj)
LG OLED65CX Pris 3099 Euro = 23.139,92 kr (kommer April)
LG OLED55CX Pris 2299 Euro = 17.166,40 kr (kommer April)
LG OLED65CX Pris 1799 Euro = 13.432,95 kr (kommer Maj)
https://www.displayspecifications.com/en/news/82c82c8
Vi bør nok også have dem med nede i konklusionen (får det tilføjet), men de danske priser fremgår i testens introduktion :)
Der ligger også en artikel på forsiden med dem: Danske priser på LG CX OLED
#311719
Desværre er 2020 OLED-panelet (i LG CX) stort set uændret efter udviklingen i OLED-panelet ramte en stopklods for 3-4 år siden
Jeg har læst dette flere gange i jeres tests af LG OLED TV. Kan nogen opfriske min hukommelse... Hvad er det præcis, der henvises til?
Tak for en god anmeldelse!
#311723
Depechefan skrev: 25. mar 2020, 09:27
Det er nok at man ikke kan hive mere lys (flere nits) ud af et OLED panel som det er nu.
#311724
Supergris skrev: 24. mar 2020, 16:19 at I er gået tilbage til at stave refleksioner med "t", selv om det er en svær én...
Mon ikke det handler om alder, nogle skriver stadig linier andre gør som dansk retskrivning ordbog anviser, at skrive linjer.
Det er nok mere et generations skifte, og hvor længe siden det er man gik i skole, og hvor ofte man læser om ord ændringer.
#311726
Steenfeldt skrev: 25. mar 2020, 09:29
Rasmus Larsen skrev: 25. mar 2020, 07:56 Det plejer at ske, så det virker sandsynligt. Jeg tror godt, at 55" C9 kan komme ned i 7999 kr. igen før den udgår. Jeg tror dog ikke, at den bliver meget billigere end det.
Hvornår regner du med det sker? :)
Alt er jo rent gætteri . Mit gæt er,at det når at blive udsolgt inden det når ned i 8000kr . . .
#311729
For ca. 3-4 år siden tog OLED-panelet fra LG Display skridtet til HDR. I den forbindelse løftede man den maksimal lysstyrke til 700 nits, farverummet til 99% DCI-P3 og nogle andre parametre.
OLED-panelet leverer det samme her i 2020 plus/minus.
Næste skridt ville være at f.eks. hæve lysstyrken til 1000 nits eller højere. Og komme tættere på det større Rec.2020 farverum, som er specificeret i HDR.
Det lader dog til at fokus mere er på at øge masseproduktionen end at tage næste skridt. Det kan man jo for så vidt godt forstå, men nok også en konsekvens af, at LG Display fortsat er den eneste som kan producere OLED TV-paneler. Hvis f.eks. Samsung Display også begynder, så tror jeg, at de to parter vil presse hinanden fremad.
