Gamer du meget, så er det Q70.
Højere lysstyrke i SDR, så.et det XF90.
Bedste Antirefleks, så er det XF90. Avsforum skriver:
"Depending on the room, the 900F gets a bit brighter and handles reflections a bit better. That could certainly put the X900F as the better choice.
Assuming you aren't getting a calibration, the 900F will have much more accurate color out of the box if that matters to you and follows the EOTF a little better. The 900F has a significantly better gradient. If you are aren't watching in complete darkness, the blooming others talk about is a non issue. I personally don't care what anyone else says in regards to motion. I have owned both Samsung and Sony, and I think the motion handling is noticeably better on the Sony even if a raw simplistic number shows them both the same."
https://www.avsforum.com/forum/166-lcd- ... html?amp=1
Bedste til sport og Action med hurtige scener, så er det XF90.
Rtings er enig og måske har Samsung løst problemet med undertekst belysningen ved en opdatering?
Men hvor finder du XF90 til under 6000 kr?
