#267679
Software history
Philips
2K17 641
2
/6482/7002/7502
8102/
8602/
9002
/973/873
ranges
TPM171E
_
003.000.20
8
.000
Date: 2018
02/09
Supports i
ntroduction of OLED873 and OLED9
73 range
Amazon is now certified and preinstalled
Improved audio performance for
55POS9002
Fix to ensure successful updating of the remote control (
BT
RC6H)
Fix to avoid connection loss and pairing issues with remote control (
BT
RC6H)
Improvements for
4K
USB
playback
YouTube v2 playback improvements
Improvements in stability
Improvement
s
for auto start
up
TPM171E
_
003.000.173.001
Date: 2018
01/08
Android 7.0 based software
Update of Google apps
Reduced Upgrade time
Improvements in DVB
T2 broadcast reception
Improved PQ tuning for 8602 range
Improved audio tuning for 55POS9002
Enable
checking for new SW during virgin installation
Fix for
smooth streaming
for
Blockbuster
app
with
Fix to avoid
Ethernet connection
loss
Fix for "The c
hannel list has been updated" OSD
staying
on screen
all the time
Fix for TV going back to standby
automatically
Fix for
“Scrambled channel" OSD
after channel installation
Fix for
HbbTV notification
being
shown
sometimes when
HbbTV
was
deactivated
Security fix for WPA2 protocol related to
Key Reinstallation Attacks
(KRACK)
Update for channel logo’s
Updated translation string database
#274224
MarkB skrev:Kan man slå Ambilight helt fra, hvis nu man ikke gider at have det kørende til alting?
Ja, sagtens.
#276093
Jeg er lidt i tvivl omkring Smart TV og indbygget Chromecast. Der er nogle ting jeg gerne vil kunne:
- Se Netflix i 4K enten via App på TV'et eller gennem browseren på min Macbook. Vil også kunne se HBO, men ved, at de ikke understøtter 4k.
- Kunne bruge TV'et som computerskærm når jeg browser, skriver mails, skriver i Word etc.
I dag på mit gamle TV, forbinder jeg TV og Macbook med et HDMI-kabel og så projiceres computerskærmen over til TV'et. Vil jeg kunne gøre disse ting trådløst med dette Philips TV?
#276105
Du vil ikke kunne bruge skærmens Chromecast til at spejle din skærm. Dertil er forsinkelsen ganske enkelt for høj. Og det virker i øvrigt kun fra Chromebrowser og med de ting du viser deri C ikke som generel spejling af skrivebordet. Du kan spejle Android fra en telefon eller tablet, men stadig med en del forsinkelse. Det bliver du skær af at se på.
Du kan dog sagtens bruge et HDMI-kabel som du gør i dag.
#276112
Torben Rasmussen skrev:Du vil ikke kunne bruge skærmens Chromecast til at spejle din skærm. Dertil er forsinkelsen ganske enkelt for høj. Og det virker i øvrigt kun fra Chromebrowser og med de ting du viser deri C ikke som generel spejling af skrivebordet. Du kan spejle Android fra en telefon eller tablet, men stadig med en del forsinkelse. Det bliver du skær af at se på.
Tusind tak for svar.
Så begynder jeg at tvivle på, hvad jeg har at bruge Chromecast til.
1. Netflix og Youtube kan jeg se via app'en på TV'et; her kan man også logge ind med sin Youtube-bruger og have adgang til de kanaler man følger, formoder jeg?.
2. For at se HBO og spejle computerens skærm, skal jeg benytte HDMI-stik.
3. Kan jeg finde 4k indhold via computeren og sende til TV'et via HDMI, eller går det tabt i HDMI'et?
4. Skal jeg en dag bruge Chromecast til at forbinde med min mobil, skal jeg så have en android tlf. eller? (pt, har jeg Windows Phone og den næste bliver nok iPhone)
#276113
Nej, du kan godt caste HBO, en det skal ikke være fra din PC, men fra din telefon, men en Windows Phone dur nok ikke dér.
4K via HDMI stiller krav til porten på din PC. HDR er generelt noget biks fra en PC lige nu.
#276118
Så når jeg en dag køber en Iphone, kan jeg caste fra den, inkl. 4k indhold fra diverse apps.
Men indtil da, må jeg få 4K ting fra de apps som allerede er på TV'et, herunder, Netflix, ikke?
Tak for hjælpen :)
#276120
Du kan caste 4K fra de apps, som har 4K, men det er begrænset hvilke det er. Så vidt vi ved understøtter den indbyggede CC ikke HDR, så den er lidt amputeret. Google har endvidere ikke tilføjet mulighed for at ændre frekvens på den, så den er låst til 60 Hz, hvilket er et problem hvis man caster eksempelvis DR TV. Ideen med CC Built-in er fin, men Google har bare ikke formået af følge den ordentlig til dørs og lader den til stadighed være en sølle skygge af deres dedikerede dongle.
Vi er lidt skuffede kan du nok fornemme, og af samme grund har redaktionen adskillige Chromecast dongles vi bruger i stedet, da de virker bedre.
#276122
Jeg bliver vist kun mere forvirret. Det kommer sig nok også af, at det er meget få Apps jeg føler jeg har behov for. Bruger min browser til det meste på telefonen.
1. Køber jeg TV'et, kommer det med en Netflix app på, jeg skal blot tilkøbe abbonnement, og så kan jeg se Netflixes 4K indhold, ikke?
2. Køber jeg en iPhone, kan jeg ikke caste 4K indhold fra iPhone til TV, da den indbyggede Chromecast ikke understøtter dette. Her skal man købe en separat Chromecast. Er det korrekt forstået? :)
