Sharps og SONY's 2010 modeller anvender allerede de nye Sharp UV²A-paneler.
Under tekniske specifikationer for både Sharp LE810E og LE820E står der at de har UV²A-paneler:
http://www.sharp.eu/cps/rde/xchg/dk/hs. ... lcd-tv.htm
Panel teknologi 3D / UV²A ..... - / •
Og SONY anvender også allerede de ny Sharp UV²A-paneler i nogle af derse 2010 modeller. Følgende link bekræfter at SONY EX700 anvender det nye Sharp UV²A-panel:
http://www.displaysearchblog.com/2010/0 ... new-bravia
What’s Inside My New BRAVIA
2010 March 29
I purchased the 40” Sony BRAVIA KDL-40EX700.
...I asked the Sony sales clerk who made the LCD module, and he responded that “we buy panels from a variety of makers and can’t tell whose panels go into every set.” But with the help of a 10X magnifying glass, I was able to determine that the set uses a Sharp UV²A optically aligned cell.
It was a little challenging to take a clear photo with a hand-held digital camera through the magnifying glass, but even so, the distinct square shaped, double four domain RGB sub-pixels of the UV²A panel are identifiable in the following figure.
Figure 2: ASV Conventional VA versus UV²A Pixel Structure
Source: Image on left is from Sharp.
Sharp’s optical alignment technology uses a patterned photo sensitive polymer that enables wide viewing angle performance without the conventional VA features. This reduces light leakage, which improves black and contrast levels, as well as reducing liquid crystal response times.
Sharp is heavily promoting its UV²A technology on its own sets, but Sony doesn’t mention the fact. Despite offering improved image quality, I guess they don’t want to advertise their reliance on Sharp...
Så hvis du har et forstørrelsesglas kan du gå rundt i butikker og lege Sherlock Holmes og se hvilke TV der er udstyret med de nye UV²A-paneler. Opskriften på hvordan du genkender UV²A-paneler med et forstørrelsesglas er givet i ovenstående citat.
Men Sharps dyreste model UV²A-panel, Quattron med 4 farver (YRGB) må nødvendigvis se anderledes ud end ovenstående foto igennem forstørrelsesglas. Men det er så vidt jeg ved kun Sharps dyreste 2010 modeller der anvender Quattron og så vidt jeg ved bliver de ikke solgt til andre TV-producenter i 2010.
Her er en der har skilt et SONY EX700 TV ad, og der et klistermærke bag på panelet som bekræfter at der er tale om et Sharp panel:
http://www.fullhd.gr/2008-03-14-21-37-3 ... ex700.html
Sharp modelnummeret er LK400D3LA4B, som man også kan læse her:
http://avclub.gr/forum/showthread.php?p ... ost1196176
55EX500 LTY550HJ01 SLCD
46EX500 LTY460HJ01 SLCD
40EX700 LK400D3LA4B Sharp
40EX500 LTY 400HF06 SLCD
46EX500 LTY 460HJ01 SLCD
32EX500 LTY 320HF01 SLCD
37EX500 T370HW03 AUO
46EX402 LTY 460HM01 SLCD
37EX402 T37HW03 AUO
32EX402 LTY 320HM01 SLCD
32EX302 LTY 320AP04 SLCD
55EX500 LTY 550HJ01 SLCD
EX700 = Sharp UV²A-paneler
37'' EX500/402 = AUO
32/40/46/55'' EX500/402/302 = S-LCD (S-LCD = Samsung og SONYs joint venture)
Så ligesom Philips anvendte deres egne joint venture paneler LG.Philips i billigere modeller og Sharp paneler i de dyreste modeller, så ser det ud til at SONY gør nøjagtig det samme.
SONY bruger Sharp i den dyre EX700 model, i de billigere EX500/402/302 modeller bruger de en blanding af AUO og S-LCD (Samsung/SONY joint venture) paneler afhængig af størrelsen.
Til deres 37'' EX500 og EX402 modeller anvender de AUO-paneler, sikker fordi S-LCD ikk fremstiller 37'' paneler.
Til alle de andre størrelser af EX500, EX402 og EX302 anvender de S-LCD-paneler.
At forskellige panelfabrikater bliver anvendt til samme modelserie afhængig af størrelsen bekræfter også at testresultater ikke er så meget værd som man umiddelbart skulle tro. Selvfølgelig skal panelerne opfylde nogle minimumskrav som SONY har opstillet. Men jeg er sikker på at der er en række forskelle på panelerne fra f.eks. AUO og S-LCD, som gør at de ikke tester ens. Derfor kan man heller ikke regne med at hvis f.eks. et 40'' TV er blevet testet, at man kan forvente samme performance af 37'' modellen i samme serie.
Så man skal tage testresultater med en gran salt. Det kan også være e af grundene at forskellige tests udviser noget forskellge testresultater for samme modelserie. De kan let indeholde forskellige panelfabrikater.
Jeg ved at Samsung også anvender forskellige panel-producenter i samme TV-modelserie. Jeg fik at vide i Hi-Fi Klubben at der har været en del kundeklager på grund af det, fordi deres nyindkøbte TV ikke levede op til det de oplevede i butikken, på grund af at der sad et andet panel-fabrikat i det TV de købte end det de så demonstreret i butikken.
Så man kan reelt ikke regne så meget med diverse tests, fordi man ikke altid får et TV med samme panel-fabrikat som i de tests man har læst eller de TV man har set demonstreret i butikken.
Så det er lidt et lotteri at købe TV. Men så vidt jeg er problemet mest udbredt med de billigste modelserier.
Det kunne være meget interessant at få testet f.eks. både 40EX500 og 37EX500, for at se hvor stor forskel der er i testresultatet. Og så bagefter også sørge for at pille bagbeklædningen af for at få bekræftet at de rent faktisk anvender hhv. S-LCD- og AUO-paneler.
Det er interessant at både Philips og SONY ser ud til at anvende Sharp paneler i deres dyre modeller og andre fabrikater som LG Display, S-LCD og AUO i deres billigere modeller. De må jo mene at Sharp panelerne er bedre end det som LG Display, S-LCD og AUO kan tilbyde. Dyrere modeller har typisk også højere frame-rate, så derfor anvender de andre og hurtigere panelmodeller end de billigere modeller.
De har iøvrigt skilt mange andre TV ad på samme græske hjemmeside:
http://www.fullhd.gr/2008-03-14-21-37-34/teardown.html
De har blandt andet også skilt det her testede Sharp Aquos LC-46LE820:
http://www.fullhd.gr/2008-03-14-21-37-3 ... rdown.html
Her er modelnummeret på panelet i LC-46LE820. Fotoet er dog i en lav opløsning så teksten er ikke så let at læse. Men så vidt jeg kan se hedder panelet LK460D3LWADY. Tidligere 46'' Sharp paneler har også heddet noget med LK460D3L, som man kan se hvis man søger på nettet, så modenummeret er nok ikke helt ved siden af.
