21. aug 2017, 15:03
#255625
http://www.forbes.com/sites/johnarcher/ ... 3b66725b3e
Spændene læsning, især at Oled vinder over LCD Fall tv i hdr kategori, trods deres overlegne styrke i lys styrke peaks, det viser at der er andet end nits som tæller i hdr.
Jeg søgte lidt på Google om eventet, og faldt over gutten her fra avsforums.com som var med til eventet.
Han er overrasket over hvor tæt eller lige frem bedre, LG er i forhold til Sony og Panasonic. Han mener at LG er den bedste pakke og samtidig er han skuffet over sony'en ikke var bedre end den var i direkte konkurrence med de andre.
Han kommer med gode argumenter og lyder til at have styr på det.
"I was at the event. Let met get a few things out of the way which are important. Vincent, Tyler and the Crampton and Moore crew did a phenomenal job at the event. It was an absolute pleasure to be there so thank you all for putting this on and spoiling us!
Outside of Tyler, I was the only American there and as such, I have no British reserve in me. I was happy to ask questions and point things out when something seemed odd. Any oddities were quickly addressed and the having a large array of content made this extremely valuable.
For a TV nerd, this was the perfect opportunity to see the top sets in their settings calibrated by experts.
The sets were (in order of display):
- LG B7 OLED
- PANASONIC EZ1002 OLED
- SONY A1 OLED
- Reference: Sony OLED professional monitor
- SAMSUNG Q9 LCD
- SONY ZD9 LCD
Here are my findings in relation to the main categories:
Best Gaming TV: LG B7 OLED
LG = Low input lag and great punch in HDR. The LG and Sony Z9D were immediate standouts when the feeds came up (winner)
Panasonic = Higher input lag and not as much punch in HDR as the LG
Sony A1E = Input lag dependent on source feed. HDR not as good as LG
Samsung = Game mode had sharpening applied (could be calibrated out?) and HDR implementation heavily favors detail over brightness which reduces it's impact
Sony Z9D = Input lag dependent on source feed. Great HDR (2nd choice)
Best HDR TV: LG B7 OLED
LG = Great in low light HDR. Bright picture HDR is the best among OLED's. Great balance in tone mapping with Dynamic Contrast set to low (winner)
Panasonic = Great in low light HDR, bright picture HDR lacking punch. Tone mapping is a good balance but the lack of HDR punch is clear compared to the LG.
Sony A1E = Good in low light HDR, bright picture HDR lacking punch. Tone mapping is a choice a between Cinema Home and Cinema Pro settings. Both are not great options. Either you get a dim pic or blown out details.
Samsung = Very poor low light HDR performance put this set well behind the others.
Sony Z9D = Ok in low light HDR, bright picture HDR is great. Tone mapping doesn't come into play as much due to the high peak light output the set is capable of. (2nd choice)
Best Living Room TV: LG B7 OLED
LG = With the lights on and still looking for a punch picture with various sources, the LG will do a great job (winner)
Panasonic = Top PQ but the ABL is noticeable compared to the LG (2nd choice)
Sony = PQ on part with LG but ABL performance is the worst out of all the OLED's present
Samsung = Even in daytime viewing the poor black level/dark scene performance is inexcusable
Sony Z9D = Being a FALD set has it's limitations even in a daytime viewing setting. The motion artifacts on the Z9D were quite pronounced which takes it out of the running
Best Home Theater TV: Panasonic EZ1002 OLED
LG = Great all around but it's main benefit a higher peak output is neutralized in a critical viewing environment
Panasonic = The better colors and detail compared to any of other sets made this set standout (Winner)
Sony A1E = PQ similar to LG but smooth gradation is great feature making this a runner up (2nd choice)
Samsung = Absolutely not. There are no positives here.
Sony Z9D = As great as the Sony is (miles better than the Samsung) it's just plainly outmatched by any of the OLED's in a critical viewing environment
Summary: Price being equal, my choice would be the 65inch LG B7. It's top 2 in most categories and when it comes to the future needs of HDR, it pulls away comfortably from the other OLED's. It's ABL not kicking in as often makes it a better choice for SDR PQ consistency also. I was initially going to wait until next year but after having been to this event, I'm placing an order for a 65inch B7 to be calibrated by Vincent. If you have specific use cases or preferences, I'm sure most of the other sets can fit your bill. However, my viewing will be a mix of everything and for that the LG was consistently towards the top.
DV vs HDR10
Vincent made the ultimate sacrifice. He bought 2 copies of the new Power Rangers movie so we can have a comparison! The LG was showing the DV feed and the rest showing the HDR10. In this release, there was an easily noticeable different between DV and HDR10. The DV version had more depth to the picture. However, there was a bit of over saturation which was acknowledged but that didn't impact the 3D depth of the scene delivered by DV.
Random notes:
- All sets were calibrated to 200nits. This was to balance out the light pollution from multiple sets being on at the same time for comparison
- BFI = Flicker from BFI on the Sony and Panasonic was unbearable for me. The LCD's did a good job but the reduction in light output is severe
- Choppy motion on the Panasonic OLED = There was some pull down issues with motion that were fixed by turning on game mode so this is something a firmware update should be able to fix
- Red push on the QLED = I pointed this out before lunch and the team went to work on it. It was improved but still present throughout
- Smooth gradation on the Sony = Vincent showed us instance where the algorithm got confused and decided to remove the detail on tiles of a storefront. However that's something you have to look for. It's a good feature that should be enabled and kept on low"
http://www.avsforum.com/forum/40-oled-t ... ories.html
Det er spændene når de sætter tvene op side by side, kalibreret til at yde deres bedste og virkelig sammenligne modellerne. Ingen tvivl om at alle tv der er med i eventet er fantastiske skærme og ser godt ud alene hjemme i stuen.
Men det er jo til events som disse, at de bedste stikker ud
- LG B7 OLED
- SONY A1 OLED
- SAMSUNG Q9 LCD
- SONY ZD9 LCD
DV vs HDR10
Random notes:
Senest rettet af Kennyiver 21. aug 2017, 15:41, rettet i alt 1 gang.
