16. aug 2017, 17:08
#255350
Ha Ha :-)
Lidt om LG' en så vi er sikre..Fra avforums.com
UJ750 (and again UJ7700 in US, see my first post) have an IPS panel, and like all IPS panel, blacks are rubbish, contrasts are rubbish and often brightness are average, it's not subjective, it's factual, and intrinsically linked with the IPS technology...
So when you're saying things like "blacks are as perfect as you will get", or "HDR pictures are excellent to say the least" (HDR is thoroughly linked to brightness and local diming), you're just losing all your credibility...
If you've said things like "colorimetry is excellent", then OK, but "blacks", seriously?
The only case in which IPS panel don't suffer from theses points, is in High-range IPS panel...
And guess what... again... UJ750 is in the mid-range (average) LG TVs, otherwise it would have been named SJ750...
